need a replacement part number.
Discussion in 'The Garage' started by yunit, Nov 19, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    for this Tir Rod End . I need a number I can use at Autozone or NAPA.
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Link doesn't work.
    Whats the application? /forums/images/graemlins/thinking.gif
  3. blazer74
    blazer74 Member Premium Member
    Oct 18, 2001
    1,162
    76
    Brighton Tn
    ES449L /forums/images/graemlins/k5.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have NAPA chassis book, entire thing, i can look it all up, by application, and can look up part descriptions/dimensions
  5. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Making a tie rod for someone and I need a set of right hand thread D44 TRE's. 73-76 K20 D44
  6. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    TIE ROD END/DRAG LINK (AT PITMAN/STEERIN
    MOOG ES2026R TIE ROD END
    Note: front suspension; pitman arm to lh steering arm; at steering arm (rear); 2nd design; 1 required 34.97
    MOOG ES2027L TIE ROD END
    Note: front suspension; pitman arm to lh steering arm; at pitman arm (front); 2nd design; 1 required 31.78
    TIE ROD END, DRIVER OUTER
    MOOG DS841 LH TIE ROD END
    Note: front suspension; steering arm to steering arm; 4wd; 1st design; 1 required 98.28
    MOOG DS893 LH TIE ROD END
    Note: front suspension; steering arm to steering arm; 4wd; 2nd design; 1 required 78.17
    Note: front suspension; pitman arm to lh steering arm; at steering arm (rear); 4wd; 2nd design; 1 required 34.97
    Note: front suspension; pitman arm to lh steering arm; at pitman arm (front); 4wd; 2nd design; 1 required 31.78
    TIE ROD END, PASSENGER OUTER
    MOOG ES2011R RH TIE ROD END
    Note: front suspension; steering arm to steering arm; 4wd; 2nd design; 1 required 32.91
    MOOG ES449L RH TIE ROD END
    Note: front suspension; steering arm to steering arm; 4wd; 1st design; 1 required 39.14
    TIE ROD END, DRIVER INNER
    TIE ROD END, PASSENGER INNER
    I've been using http://www.buyautoparts.com to find part numbers.. the above is for a 76 k20 with a 350
