Need a saw to cut fenders
Discussion in 'The Garage' started by mccomas, Apr 23, 2005.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    Gents, I am going to cut my fenders and rockers this week. I need some recommendations for the best saw to pick up for this. Because I am going to have to buy one no matter what, I want to ensure that I pick up the right one. Not only am I looking for quality performance, I assume that I need something that I can maneuver around with ease…
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I just used a sawzall. Whatever you use, just take your time if you want it to look good.
    -Harrison
  3. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    The most effective thing I used was an air powered rotary cutting blade. Its the most accurate, the sawzall was just too hard to control and it kept slamming the blade into the back of the inner fender eventually bending the crap outta the blade. I know alot of people use sawzalls but my preference is the air saw.
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I used a combination of a sawzall, a grinder with a cutoff wheel, and a die grinder with a cutoff wheel. Any one of the three will work just fine.
    Edit: I will admit the sawzall is a bear to control but I had to go through a large fender support to cut my front fenders and it was the only thing that would work.
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Use an angle grinder with a 1/8" grinding wheel or a cutting wheel. Sawzalls deform the metal too much not to mention the more you try to dictate where it goes the least likely it is to go in that direction.
  6. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I used a combination of an angle grinder and a small air saw that I borrowed from another member here. Used the grinder for places that were too tight for the saw.
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    An air nibbler or shear would be best I think! Very precise cuts and no deformation of the metal. If I do much body work this summer I'm going to get one of the two.
  8. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
