Need a SBC 350.
Discussion in 'Parts & Trucks Wanted' started by ncbloodhound, May 27, 2005.
  1. ncbloodhound
    ncbloodhound 1/2 ton status
    Aug 18, 2003
    400
    Indian Trail, NC
    I need a rebuildable SBC 350. It needs to be within 300 miles of Charlotte, NC. I prefer a TBI or MPI.
    I have Pontiac 350 to trade if interested.
  2. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    ive sot an 89 g motor from 3/4 4x4 sub w/the big valve stem heads, 2.02,1.68 its got a rod shaped hole in the pan though but if youre interested i'll pull it apart and check the bore for damage
    its 1pc rmain and was tbi but no tbi unit
  3. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i have one from a 91 k2500 $300 in ga.
  4. ncbloodhound
    Aug 18, 2003
    400
    Indian Trail, NC
    Can you both please tell me a little more about the engines...
    mileage, how complete, running when removed, etc?
    Thanks!
  5. gambit420s
    May 17, 2005
    294
    ok its actually 11/32 valve stem heads
    but <100k,
    complete from pan to intake
    no tbi, missing cap and electronics on distributor
    ROD SHAPED HOLE in oil pan, will check bore if serious
    at minimum needs one new rod, bore job, pistons, oilpan, tbi/intake w/carb, distributor
    do have edelbrock spread bore intake and stock 100k mi hei dist that could go with it
  6. 4x4k20
    Mar 17, 2001
    1,699
    williamson ga.30292
    the one i have is from a 91 k2500 it was running when pulled .it had low oil pressure. complete long block. no intake .has the valve covers .it had 140k on it. also i do have a couple 350 vortecs that need rebuiling they are mostly complete they have the intakes $350 each
  7. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I've got one from an 87 K10. Ran when removed but smoked like cheech and chong. Definately needs a rebuild, I've never opened it up though. Its complete minus throttle body, dissy and sensors. The exhaust minifolds I removed but they can go with it. No alt, starter, smog, or a/c compressor, however I've got some for cores if you need them too. Still has the tbi intake. Its the center bolt heads. I'm not sure of the miles but I would say at least 150xxx. I bought the whole running truck for the tbi and wiring. Make me an offer, I'm easy to deal with and I'm about an hour south of Charlotte in SC. PM me and I can give you my # if you want to talk.
  8. ncbloodhound
    Aug 18, 2003
    400
    Indian Trail, NC
    Thank you for your replies! I have found a 350 here locally that I am going to get. Thanks again.
