need a set of 60/60's, which truck to pull from?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NFG, Oct 16, 2001.
  1. NFG
    NFG Registered Member
    Oct 16, 2001
    8
    need a set of 60/60\'s, which truck to pull from?
    I am about to aquire a fullsize blazer frame and am gonig fully custom suspension on it. I should have clearance for 38-44 inch tires (still debating how high I want to go) so I want a set of 60's front and back (or 70 or 14 bolt rear) which truck should I look for as a donor vehicle?
  2. lv2whl
    lv2whl 1/2 ton status
    Mar 4, 2001
    130
    CA, USA
    Re: need a set of 60/60\'s, which truck to pull from?
    i would get axels from any K30 chevy, up through '87. They had a Dana 60 in the front and a 14 bolt in the back. Plus with the 14b in the back, a locker will be cheap, compared to other axels. At least thats what i would do.
  3. NFG
    Oct 16, 2001
    8
    locker? I'll just weld teh spider gears, a 14 bolt is strong enough not to snap axles despite a ton of power. a k-30? sorry, I'm new to chevy's, I'm a jeep man myself but am being given a free frame to work with....I am going custom coiled front and shackle flipped with lift springs rear, this setup is set to give a YJ wrangler 12 inches of lift, so it should do ok on the blazer I would think.....
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    *looks around*
    is this coloradoHEEP?[shcoked]
    no...it is colorado k5 [​IMG]
    in all seiousnessess 12 inch lift would mean 8 inch springs with a 4 in flip. that is a whole lotta stiffness in those springs unless you pay BIG duckets for a kustom set. why not build a hybred? ( i need speel cheq on this thing) you have the frame, now just build a flat bed and sell the fenders...
    early 90's dodge 250's have dana 60 rears and are semi-common in the yards, but i would loof for a 14BFF plus the ever elusive D60 35spline front
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  5. lv2whl
    Mar 4, 2001
    130
    CA, USA
    a k30 is a 1 ton chevy 4x4 pickup truck. sorry about that. yes, i would weld the gears too, but if you were interested in a locker, its the cheapest way to go. What kind of springs are you going to use inthe rear? Are you going to have a blazer body on it? A shackle flip in the rear is the way to go, but that only gives you 4 in of lift in the back. I dont remember how tall you were going, but if you have a cage body and such you can go relatively tall in the tire dept. without alot of lift, thus remaining flexy.
  6. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    look for 77-91 k-30 chevy trucks. they all have the goods from the factory.
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Best bet is to find a K30 from 1977 to 1987.... if it's not been picked over yet it will have a Dana 60 front and 14 ff in the rear.... [​IMG]
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I keep trying to lose weight, but it always finds me!
  8. NFG
    Oct 16, 2001
    8
    Like I said, I'm a Jeep guy...I will probably either custom mat a CJ-8 tub to it or I will use a 1948 willy's puckup cab and a custom bed...or I might use a Jeep M-715 body and bed....too many options!
    I was thinking about using Dodge Dakota four inch lift springs (MAJOR arch and an offset pin to lengthen wheelbase) combined with the shackle flip. up front I am using a 4.5 inch grand cherokee lift coil with the coil mount flush with the frame and I'm trying to track down a set of FJ80 control arms to fab on.
    The hardest part here is finding the right parts for the right $ and then of course the time this is taking will be a pain in the butt. It should be a fun project though. I do have the body and fenders from this fillsize, they aren't in the best condition but they may be better than what ya'all are currently running (heck, I dunno....) make me ANY offer and they're yours.
  9. Dip Stick
    Dip Stick Registered Member
    Oct 14, 2001
    73
    Murdock, Florida
    Looks like I need to throw in my 2 cents. . .From 73 to 80 or 81 The 14 bolt was a FF with a 10.5" ring gear. From 81 or 82 on it was a SF with a 9.5" ring gear. All of the dualies, I think, had 70's out back. For the front they all had 60's no matter what year. Just a little info from www.ChucksChevyTruckParts.com
    It's not what you drive, it's how you drive it.
    1986 K20 350 700R4 208
  10. tRustyK5
    Jul 23, 2000
    36,169
    1,370
    E-town baby!
    The FF was never discontinued...the SF was introduced in the lighter duty 3/4 tons. The FF remained in the rear of the K30 as late as 87 at least.
    Don't believe everything you read on Chucks pages...[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  11. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I have a dana ff 60 for sale needs pinion bearing 4:11 gears $100
    colin
    Save the whales Harpoon a fat chick.
  12. NFG
    Oct 16, 2001
    8
    hey k5blazerus, I am extremely interested, where are you located? please e-mail me at mklotz@msn.com
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    K30s were made until 1991, weren't they?
    Well, they called them V30s or something, but that's what I'm talking about.
    Tim
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, 1 tons were made clear up to '91.
    Yep, they are classified as a "V30". '87 was the year they switch the "K" to a "V" classification.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Awww, come on now!!! Chuck is the 'all-knowing' man!!! [​IMG]
    Well, he is correct on most stuff, but, not everything!!! [​IMG] [​IMG]
    You are right about him, don't believe everything he says!! [​IMG]
  16. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    14FF were still on 1993 3/4 ton with 454's - I still own one.
    <font color=blue>azblazor</font color=blue>
    <font color=orange> 79 K5 454-FI / 4L80E, NP205, D60, FF14, 4" lift, 9K Warn </font color=orange>
  17. NFG
    Oct 16, 2001
    8
    ok guys, I am now in search of a junkyard 1970-1991 k/v-30 with the 60/14 combo........but what are the gear ratios on those guys?
  18. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have seen 3.73, 4.10, and 4.56 although you can go all the way to 5.13 w/ aftermarket
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  19. NFG
    Oct 16, 2001
    8
    any way to differentiate without pulling the cover or spinning the yoke while a friend watches teh hub? axle ID's, or particular option packages? 4.56 factory gears? that I've never heard of but would KILL to find.....
  20. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I was at a junkyard yesterday looking through the parts reference and they ran from 3.42 to 4.56.
    John
