need a smallblock mesurment
Discussion in 'The Garage' started by mudhog, May 24, 2005.
  1. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i need a mesurment of how much room is between the harmonic ballancer and the timing cover?
  2. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    is this a brand new harmonic balancer, or an old one with a speedy sleeve on it (harmonic balancer repair sleeve)... with the sleeve on, it doesn't quite go in as far (but the difference is negligible since the belts still line up with the pulley on
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it is a brand new one. both mine and my dads only have about 1/8th of an inch gap. but a friend is putting a brand new motor together with a new aftermarket ballancer (also tried a stock one) and they go all the way on but he says that he has like 9/16ths of an inch gap and it just dont look right.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I just received a car with running small block , and the outer balancer had seperated , all belts line up and the balancer outer half had room to sit behind the remaining balancer and spin with the engine and rub cover .
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    There are two different width harmonic balancers. Maybe you have one of them on yours and your buddy has the other type that is thinner.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    his looks to be the same size as mine :confused:
  7. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    The difference is probably in the part that fits on the crank, his may be longer. Some small blocks were built with short waterpumps and some are long style. So I think the dampner has different spacing as well........and I could be so far off base its not funny. Hope that helps.
    George
