Need a Torque converter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazinBaldy, Nov 10, 2002.
  1. BlazinBaldy
    BlazinBaldy Registered Member
    Jun 10, 2002
    10
    Pismo Beach, CA
    My torque converter went out on my Blazer and I need to replace it what shoud I get? I have been told so far that a towing converter is what I need, but I want to run 35x12.5 tires and dont want it to lug. /forums/images/graemlins/k5.gif
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    It would probably help if we knew a little more info. Like: gear ratio, engine mods, transmission, type of wheeling you do, etc.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    This might make your decision...
    New Performance converter = $300
    Stock Replacement = $95
  4. BlazinBaldy
    Jun 10, 2002
    10
    Pismo Beach, CA
    I am running a stock 350 motor and I want to put 35's on it. I mostly go wheeling in the sand dunes but I also go in the hills on dirt/mud trails.
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    For sand and mud you might want a higher stall converter (2000+), rock crawlers really benfit from the low stall towing converters (1300-). A high stall will generate more heat and is harder on your tranny in heavy load situations, the low stall runs cooler but requires a bit more torque to get moving quick. Either way, get an external cooler to run in line with the stock one in colder climates or to bypass the stock one in the radiator in warmer climates. Cheap assistance against premature wear due to heat generated by torque conveter slippage.
