Need a torque spec......Pleeeeeze
Discussion in 'The Garage' started by 88Silverado, Aug 18, 2006.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    What is the torque value on the nuts holding the rear transmission mount to the crossmember?? Just replaced mine and snapped the bolt with a 3/8 ratchet :mad: :mad: :mad:
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I dont see a spec in my book for it, but I would say about 20-30 ft/lb. I cant believe you snapped the bolt. Is it grade 8? I know mine is.
    Ive got an Energy Suspension mount, and it has 2 bolts that go through the crossmember to the mount.
  3. millpondmonster
    millpondmonster Newbie
    Jan 31, 2004
    chehalis wa.
    If I remember right.......that would be a 7/16 bolt ( a 5/8 socket fits it ) and should torque to 40-45 ft. lbs.........original one must have been getting weak
  4. 88Silverado
    Mar 13, 2003
    2,664
    Thanks.
    Its a brand spankin new NAPA mount made in India :rolleyes:
    Guess I got the good stuff.
    Yes, its the 7/16 studs with locknuts. Felt like it was starting to snug up, then snap! :mad: :mad:
    My manual has a 40 ft/lb for a "Manual" trans but nothing for Auto trans. Have to assume its the same. Hope NAPA replaces it. If not, Ill go somewhere else.
  5. millpondmonster
    Jan 31, 2004
    chehalis wa.
    no problem, good luck.....
