Need advice for idle problem with engine just installed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by vegas76k5, Aug 30, 2003.
  1. vegas76k5
    vegas76k5 Registered Member
    Apr 20, 2003
    31
    Las Vegas, NV
    I finally got my freshly rebuilt 350 installed and the cam broke in. Now that I am trying to fine tune it, I can't get it to idle at the right RPM. It idles way to fast. After it warms up, the idle does drop slightly, but not low enough. I have the screw in the carb adjusted for the lowest idle already. I tried spraying carb cleaner at the sealing surfaces with the engine running and had no change in engine speed. I was told I will have to pull the intake manifold off and use RTV on top of the gaskets. Before I do all that, I figured I would see what you guys say.
    BTW - It is a 76K5, rebuilt 350, used Holley aluminum intake manifold, new Truck Avenger carb, new Accel HEI distributor.
    Thanks for any help.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Get out the timing light, and make sure that is set correctly....
    Use a vacuum gauge and shoot for the highest reading when adjusting the idle mixture....
    Look for a screw on the linkage that will back the carb off some and idle it down too....
    Good luck.....
  3. vegas76k5
    Apr 20, 2003
    31
    Las Vegas, NV
    Problem solved
    Thanks for the help. I got it working right early this morning. I have never had a vehicle with a carb before. When I hooked the throtle cable up I didn't realize once the choke comes off the linkage moved that much. The cable was holding it like I was pressing the pedal.
