Need advice on tune-up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, Sep 4, 2002.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    Hey guys, gonna change all my hoses, belts, and radiator on my '88. Are there any tips you could give me to help out? One of the stock heater hoses that goes to the top of the intake turns to metal piping the last 10" or so. Someone mentioned I could cutoff the stock hose where it joins the pipe with a hacksaw and clamp the new hose onto it.
    Also, my tranny cooler is mounted to the front of the radiator, is this a bad setup? My brother in law said I should bolt the cooler to the sides of the grill support so it doesn't rub the radiator. He did this on his Sub...
  2. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    do yourself a favor buy a 3 or 4 core radiator. you will never have to worry about an over hating problem again. as for the tranny cooler, ive seen guys run them on both sides and as long as they are fastend tightly they wont rub your radiator. and yes as long as you cut that pipe while its off your truck (no need to get metal shards all over your engine) you should be able to clamp it and it should be ok.
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Use some tubing cutters. The cut will be cleaner and there will be a lot less metal filings. I would also recommend changing the quick connect that screws into the intake. This part is alluminum and they often rot out pretty quickly, I've seen several of them do it. My dad had to dig one out of a 92 Blazer and a 97 GMC and it wasnt too fun.
  4. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    Thanks for the advice... looks like I'll be investing in a tube cutter!
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You would be well enough to leave the heater hose to the intake alone, unless it needs replacement. Those things are super touchy and the fitting always breaks off in the intake. If it ain't broke, then don't fix it. If it is in need of replacment, than you've got the right idea.
