Need advise on painting my rocker panels
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Jan 6, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I want to paint my rocker panels using the roll on herculiner. Id like to paint the bottom 8" of my rig all the way around. Is there an easy way to get a strait and level tape line?
  2. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    Just clean off the area where the tape will be applied really well and stick down the front end, by the wheel well or wherever your starting from. Roll out the tape however far you need it and get eye-level with it. Then just pull it tight and stick down the other end where you want it.
    Also, you might go by a pro spray-in shop and see if they will sell you some of their "wire tape". It is VERY expensive, but it will trim you line for you without any hassles. It's good stuff!!
    HTH,
    Buddy
    I've got my dream truck and it's a 72 K-5 that is getting there!!
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    ok here is what ya do. take a grease pencil and measure up 8 inches and mark it with the grease pencil, then move 1 foot down and do it again, and then again till you have done it all around. then take the tape and line it up with the marks then it will be and even straight line.
    the closer you make the marks the straighter the line will be.
    then after your done and take the tape off, the grease pencil can be rubbed off.
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    K5: Because size DOES matter
