Need advise quick on Brake Booster upgrade
Discussion in 'The Garage' started by ZZ4x4, May 17, 2004.
  1. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    My master cylinder failed big time this weekend and there is brake fluid running out of the booster /forums/images/graemlins/eek.gif. Thought it would be a good time to upgrade to the 3/4 ton booster and cylinder. I read the other post last week saying the 1-ton booster/ cylinder requires too much foot pressure and to get the 3/4 ton unit. This sounds strange to me. Then I looked up the part numbers. For a '79 for example, the 3/4 ton and 1 ton have the same part numbers if you have the JB7 brake system. The other option on the 3/4 ton is the JB6 (7800 lb GVW) system. I'm thinking that the JB7 (8200lb GVW) system can be identified by the 13" 14B rear rotors as opposed to the 11" rotors??? I do have the bigger rotors so should I get the JB7 master and booster or go with the JB6 stuff. Please let me know what you did, if you've done the conversion.
    Thanks,
    Jeff
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, I went with the JB7 stuff when I upgraded mine and they work great /forums/images/graemlins/thumb.gif
  3. ZZ4x4
    Oct 17, 2001
    542
    Garland, TX
    Excellent. Thanks. Did you notice lots less brake effort required? I didn't really have a problem with the brake effort before, but less effort would be a plus.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    There was a very slight change, almost unnoticable really in the effort department, but a lot better in the stopping department /forums/images/graemlins/thumb.gif
