need alittle help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jayweb, Feb 10, 2004.
  1. jayweb
    jayweb 1/2 ton status
    Jul 6, 2003
    213
    NC
    sorry for not searching - I'm at work on a SLOW computer. I need to know if a 14sf out of a 84 sub will bolt in (it is a direct fit other than the u-joints, plates and u-bolts right?) what about the brake lines? thanks for any help.
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Direct fit, if the hard lines on still on the axle then the your rubber line will bolt right to it.
  3. jayweb
    Jul 6, 2003
    213
    NC
    thanks
  4. jayweb
    Jul 6, 2003
    213
    NC
    need a little more help -- where to get disc brakes? I want to go to 4.56 gears - it has 3.73's now - do you have to worry about "thick gears" or anything?
  5. jayweb
    Jul 6, 2003
    213
    NC
    Re: need al little MORE help
    bump
