Need an air pressure regulator for the ARB
Discussion in 'The Garage' started by 2Dogs, Feb 7, 2003.
  1. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Hey All,
    My on-board air compressor is capable of running 150psi but the ARB can't take that pressure. Has anyone found a good regulator for this or similar applications?
    Pressure is the only thing I am concerned about since the ARB uses small volumes of air.
    Here are a few that I think might work:
    http://store.yahoo.com/compressors4u/regulators.html
    http://www.controlair.com/regulators/850_860reg.html
    http://www.hand-tools-power-tools.com/air_tools/air_regulators.htm
    Will the small brass unit work????? That would be best.
    Has anyone seen the ultra-cheap units at Harbor Freight? I wonder if they will work...? I worry about blowing the gaskets out of the ARB with the cheap stuff tho.
    All thoughts welcome! /forums/images/graemlins/ears.gif
    Thanks,
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just go to home depot (or your local hardware store) and pick one up...
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I got all of my OBA parts from www.mcmaster.com </font color>
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I went ahead and bought the one from Home Depot.
    Now I need to adapt the ARB fitting to the regulator (my manifold off of the pump was cut for the ARB - english threads....?). What is the type/size of fitting that I need for the ARB side?
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The thread on the ARB switch is 1/8" British thread, BSP is the abbreviation IIRC. </font color>
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Thanks Shaggy.
