need an opinion on the front end
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 72beater, Jul 1, 2003.
  1. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    ok, I'm looking at a complete ball-joint/wheel bearing/hub/u joint ( and probably gears) on my D-44. Am I better off just getting 3/4 ton 44 or, gulp, a 60, and throwing that in? I am a LIGHT wheeler, sand and river beds at the most. Someone give me an opinion? I know I am looking at a grand for a 60 minimum, and I don't know how much for a solid 3/4T 44. /forums/images/graemlins/confused.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    For just sand, and river bed type offroading, I would say a 3/4 ton 44 would be good. /forums/images/graemlins/grin.gif
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Stay with the D44. I have beat the piss out of mine and it has done fine. Make sure you keep new Spicer u-joints in it, never put a locker in it, and keep the tires under 36" and you should be fine.
  4. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    FWIW
    I would, and have, rebuild you existing D44. It should be good for another 30+ years. However, if you have the $$ to burn or are planning to put anything larger that 33s underneath, you can't go wrong by throwing something bullet-proof in the front.
    I decide to put the cash toward a new soft top and AC.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  5. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    keep in mind a 3/4 ton 44 is no stronger than a 1/2 ton...3/4 uses a diffrent hub and bearings and diffrent clapiers and spindals....strength wise they use the same ball-joints shafts and gears...
  6. 72beater
    Oct 11, 2002
    224
    Nation\'s Capital
    thanks for all the good opinions!
