need answer on fuel pump replacement quick
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rebel88, Aug 5, 2002.
  1. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    got to change it tonight and i dont have hours and hours to work on it...
    whats the fastest way to drop the tank on an 88...its the intank pump...
    bumper off or not?
    need to know quick so i can get it done
    Later
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">If you drop the tailgate you can get to the nuts on the gas tank straps pretty easily. Soak them with a good rust penatrant and try not to break the straps. Also soak the fittings for the fuel lines at the top of the tank. Use line wrenches if you can get them so you dont round off the fittings. I just did this on my 89, any more Q's just ask
  3. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    you mean put the tailgate down? or drop it totally
    i can get the the skidplate bolts on the back side of the tank(the one towards the front of the truck)
    but im not sure about the easiest way to get to the bumper side
    Later
  4. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    anybody else have suggestions?
    Later
  5. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    if your tank is anything like mine was your sol. i had to get a new tank and sender because everything was so rusted it just crumbled. fastest way is put an inline electric pump on the frame rail and forget about the intank one. i had the luxury of replacing mine with the cab off the truck and it was still a pain in the butt. i suppose you could always cut a big hole in the rear bed and do it from the top. but still a major job.
  6. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    well i got it done in just over 3 hours...is that some kind of record cuz it wasnt all that bad?
    worst part was trying to balance the tank on my knees while locking that ring back in place that holds the pump and all that in the tank...
    Later
  7. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    3 hours isnt too bad at all. It took less than an hour to do mine but I didnt drop the tank. I cut an access hole in the rear floor over the pump and did it all from the top. Even doing it from the top, that lock ring was still a PITA.
  8. dyeager535
    26,982
    191
    I just unbolted the skid plate at the front, and bent it down in the rear so it would clear, no bumper removal.
    I also drilled holes in the middle of the skid plate for drainage...did you notice the tank/skidplate was rusted right in the middle from sitting water/dirt like I did?
  9. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Scooter, where and how much of the floor did you have to cut. I may have to change an in tank pump on my g/f's 88 and am thinking of making an access hole for on trail repairs.
    TIA
  10. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    mines not rusted...yet
    but there was a water spot on the skid plate
    might have to make a drain hole myself
    Later
