Need Asap
Discussion in 'Parts & Trucks Wanted' started by big83chevy4x4, Dec 23, 2005.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    FOUND
    power steering return line, all i need is the steel line that goes from the steering box to the rubber line, mine has a hole in the bend. for my 83 with an oring box.
  2. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    my local parts stores stock the replacement lines with the 1 end flaired to the oring style you need. under 10 bucks. i find mine at napa. thay come in about a 18" long yellow package. same flair as the tbi fuel oring flair for the tbi motors.
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ok ill have to check them out. the online catalog at autozone and advance auto does not have the return line, just the pressure line.
  4. sweetk30
    Nov 1, 2004
    25,528
    527
    ya those steel replacement ends thay offer will work for p/s return also. just need to bend it your self.
  5. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    I just get a 12" piece of steel brake line with the right size fitting and bend it myself. I think it was a 3/8" line.
  6. sweetk30
    Nov 1, 2004
    25,528
    527
    wont work for him . he has the newer style with the oring flair on the end. your trick would work if it was 73-80 style box.
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i picked one up for under $3 at advance auto parts...
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the local napa or the carquest didn't have anything for a replacement line. the carquest did have a fitting for the oring to a 6AN fitting. then i they had a hydraulic line elbow that i have to cut the crimping peice off and can run a 3/8" powersteering hose on.
    cost me about $35 for all that. but its way better than the factory stuff.
  9. sweetk30
    Nov 1, 2004
    25,528
    527
    :yikes: :yikes: :yikes: i would of got ya one and shipped it for less than that. wow.
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if i could have waited, i would have done that, but i needed it 3 days ago. what can ya do?
