need axle help.....
Discussion in 'The Garage' started by **DONOTDELETE**, Jun 4, 2002.
    ok, im rebuilding a gm front 10 bolt, and i was putting in the pinion and differential today. i dont have a high enough torque wrench so i used just the impact gun to get the pinion bolt on. seemed to be tight enough. well here is the problem, when i oput the differential in, and fit it, it spins perfectly, but once i tighten the bolts for the ?????(i forgot what the part is called, it holds the berring caps down and holds in the diff. ya i know imn sutpid ) the dfferential doesnt spin. its not the berrings, because its only when i tighten the side witht he ring gear. it meshes the ring gear and pinion gear too tightly. how can i fix this problem? did i not tighten the pinion bolt enough?
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Go to this link http://ring-pinion.com/t-installation.shtml and click where it says "download in PDF format" It will help you, its the Yukon Gear & Axle Installation Kit Intruction manual....I used it when I rebuilt my 12 bolt.
