Need axles for another project
Discussion in 'Pacific Region' started by seattlek5, Nov 1, 2003.
  1. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    I need a line on a 14-bolt FF open with 4.10 or 4.56's and a Ford HP 60 with 4.10 or 4.56's. A rear FF 60 would be ok too. No fishing here, have a customer that's doing a SAS on a '95 Yukon.
    Have cash...
    ...need axles /forums/images/graemlins/1zhelp.gif
  2. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i can get u a 14ff it needs brakes..its from ocean shores.....but it would be cheep....lemme know
  3. BadBowtie1
    BadBowtie1 1/2 ton status
    Nov 5, 2002
    456
    Mill City,OR
    I have a Dodge rear D60FF if that will work.Let me know.
  4. seattlek5
    Feb 23, 2001
    311
    We're doing discs on the rear, so as long as it's 4.10 or 4.56 it will work.
  5. BadBowtie1
    Nov 5, 2002
    456
    Mill City,OR
    I think they are 4.10 gears but will double check today and get back to ya.
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Does the front axle have to be a D60?
    From the proposed ratio I am assuming that tires in the 36" range are going to used.
    My buddies dad has a 78 F250 with a high pinion, twin piston calipers, flat top knuckle D44. I haven't popped the cover off it yet to see what the ratio is, but 3:50 seems to be a common ratio with Ford. so it will most likely need to be regeared. He sold the one out of his 79 to a guy from work for $150. He just wanted the knuckles out and wants $50 for that housing.
    The 78 has been sitting for a long time and the axle will most likely need to be completly rebuilt.
  7. seattlek5
    Feb 23, 2001
    311
    We're putting 38's on and are using the 4.10's (most common D60 ratio) for now. This is a dual purpose rig, biased toward street use, that he doesn't want to worry about breakage off-road. Gears may be done later.
  8. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Sounds like a cool project.
    From the way the Bronco boys talk at work D60's for them is alot harder to come by than for a GM. and when they do locate one it is for some outragious price.
    One thing about where I live is there seems to be no shortage of Ford rigs in feilds. What year and model would be one that you will need the axle from?
  9. seattlek5
    Feb 23, 2001
    311
    '78-79 F-350 and some F-250's
  10. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Ford D60's seem to be going for about $1500.
    I did find a 14FF out of a C20 though. I haven't cracked the cover but the guy says it is a 4:10. He wants $50 for it.
    If you don't want it I am going to get it and swap it into my 73.
    For 38" tires and the type of rig it is and the application I would think a D44 front axle and a 14 FF would be sufficent.
    I am assuming that the drive train is being retained?
    To me it makes no sence to beef up the axles if the tranny or t-case will be the weak link.
    IMOHO the stock tranny or t-case will fail in that application before a D44 will, not to mention a D60.
  11. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Hey Ron, do you ever wheel up in the Dixie Mtn. area?
    -Andrew /forums/images/graemlins/usaflag.gif
  12. seattlek5
    Feb 23, 2001
    311
    We've found a rear axle locally (D60 4.56 Detroit) Still looking for a front D60 (ratio doesn't matter at this point) We may be putting in a TH400/205 or 4l80e/? later, depends on what the customer wants to do. I just don't like D44's for full-size rigs and if I'm going through all the trouble of a SAS, I don't want to see the axle break when we're out wheelin' /forums/images/graemlins/thumb.gif
