Need Bell Housing Help....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Mar 18, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well I am junking my 700/208 combo in favor of a 465/205 combo...Now I need bell housing help...What do I look for to pick the correct bell housing for my application? The setup is going on a 1987 K5 with a 350...It is going to be hydraulic clutch setup...what bell housing do I nee to mate my 350 to the 465...I am also going ot be running a centerforce Stage 2 clutch...What should I watch out for...Thanks for the help gang..
    Chris
  2. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Find a bellhousing from an 85 or newer Chev with the SM 465. Do a search too, there's been lot's of discussion about hydraulic clutch's in the past.
    Rene
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The bellhousing that you will be looking for is a one peice housing.
    It will not have a dust sheild on it. I have one that I was going to use until I found out that it was for a later 350.
  5. dyeager535
    26,982
    191
    Just make sure its not a camaro or corvette application (if they even look similar) I'd almost guarantee at a minimum, the input bearing size is different. Only say this because I've seen so many mis-marked bellhousings at swap meets. Also check that the housing to tranny holes aren't drilled out (no threads left) Not sure why someone did that to the one I have, but looks like some kind of project...just keep your eyes open. Local wrecking yard sells bellhousings for $25, but I've only found one hydraulic 465 housing.
