NEED BODY LIFT INSTRUCTIONS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyblzr1977, May 8, 2003.
  1. chvyblzr1977
    chvyblzr1977 Registered Member
    Jul 18, 2001
    83
    Pissburgh,pa
    I bought a performance accessories 3 inch body lift and i misplaced the instructions does anyone have them where they could email them to me my email address is blazerk51977@yahoo.com
    i really would appreciate it
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I might still have mine, gimme a day to look for it and i'll let you know /forums/images/graemlins/thumb.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Unbolt body, jack up 3", bolt body down, extend linkages and enjoy wheelin'. /forums/images/graemlins/smile.gif
  4. Trigger
    Trigger Registered Member
    May 5, 2003
    48
    Independence, MO
    What linkages would you need to extend in order to put lift on? steering, shift and ????
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you have an auto, you'll have to extend the tranny linkage. Leave the steering linkage alone. You're going to have to adjust your linkage for an NP 208 or NP 241 if you have one. You need to lose the bottom of your fan shroud. Make sure your brake lines by the master cylinder are long enough and that your gas filler is long enough.
    If I left anything out, hopefully someone will remember. It's been almost a year since I did mine. If you have any specific questions, shoot them my way and I'll help you all I can.
  6. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i would drill out the plastic inserts in the steering shaft and lube it up. otherwise the lift is going to put extra stress on the rag joint.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Looks like I'll have to do that to mine. I didn't.
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Your gonna have to ether take off of the tailgate springs or just cut them off. Also trim the fan shroud.
  9. chvyblzr1977
    Jul 18, 2001
    83
    Pissburgh,pa
    I was wondering if you found the intructions yet.I really would appreciate it.
  10. mcmlxix
    mcmlxix Registered Member
    Nov 28, 2001
    80
    Las Vegas
  11. ccox7
    ccox7 Registered Member
    Jul 24, 2002
    69
    Bayou State
    Thanks for that tip about the tailgate springs.I had already taken mine off and never put them back on.It would have been in a nine line bind.
  12. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Yeah, dude. Just call Performance Accessories and they should be able to fax you a copy. One other recommendation--If you don't have an impact wrench, a breaker bar is invaluable to get the old body mount bolts off. I did mine in my driveway and had I not used a breaker bar, I would have really spent more time and elbow grease on the install. I did a write-up on mine a while back. Just do a search.
    Extending the tranny linkage is a piece of cake. Just weld that 3" extension to the end of your tranny linkage. More simple than it sounds.
    Do the search for my write-up. I think it's probably better than the actual instructions.
    Hope this helps.
