Need Cam Advice
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by getsome, Mar 8, 2000.
  1. getsome
    getsome 1/2 ton status
    107
    Colorado
    I'm getting ready to take my 350 4 bolt to the machine shop and I need some help in choosing a cam. The engine is going into my 84 K5 with a 700r4 and 4.11 gears with 35" BFG's. A "rv" cam is not option. It will be a fairly stock rebuild with .030 over pistons as the only real change. I'm looking around a 440-460 gross lift and a duration of 210-216 @ .050. If you've had good luck with the cam in your K5 350 please let me know. Thanks
    Getsome
  2. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Well a mild cam with substantial low end performance is a comp cam 260. It has a nice sound to it I think it is like 112 degrees so your vaccuum will not suffer and drive ability is there. Its not a RV can. Im putting one in my .40 396 im building. It was toss up bewen a 260 or a 280. 280 was a bit wild.
  3. getsome
    107
    Colorado
    The big blocks can stand a little bumpier cam then the small blocks. The bb's start around .500 for the gross lift for int and exh at a 1,500-4,500 rpm range. Thank you for bringing up the point about vacuum. I would like to have some left over while I have my foot in it. Thanks again.
    Getsome
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    When you are selecting a cam, the first thing you must ask yourself is "what is the desired RPM range?" You should have a tachometer to make that decision. In my 79, my range is from 1500-4300rpm. I never go over that. So I wouldn't want a cam that has it's peak torque or horsepower above that. Also your rpm at cruising speeds (60mph or so) is important. Check out Crane Cams' Chevy selection page: http://www.cranecams.com/master/apps/chevy6.htm.
    I think a 210-216 cam is a good option if you like to floor it and hear a pair of Flowmasters shake the ground. I was thinking that one myself too. The only suggestion I have is that you change your cylinder heads too if you are going to upgrade that cam. I wouldn't chane one thing without changing the other.
    I think the new Vortec heads are the best bang for the buck these days. It will make a big difference with that cam, and they are only $400 fully assembled. http://www.paceparts.com even has a drilled version that'll accept your non-vortec intake manifold.
    I found this link in chevymania.com that'll show you how much of a difference the Vortec heads can make. http://www.shelby.net/mgervin/perfart.htm.
    I've never been so convinced by a magazine article as this one did.
    If you have a milder(economy) foot, then you may want to go with a 204/214 setup or the 206/214 Comp Extreme 4x4, which is in between of Cranes 210/216 and 204/216.
    I still haven't decided if 206/214 or 210/218 is the one I need, but I still don't have the bucks anyway, so I'll keep checking my tach every moment I can.
    Hope this helps
    <font color=purple>////////
    Go 79s!!!
    </font color=purple>[​IMG]
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I used a Comp Cams Xtreme Energy cam. I can't remember the number, but its the one with .447/.454 lift and 212/218 duration. It kicks ass. The idle isn't lopey, and it makes good torque AND if you rev it beyond 4 grand everyonce in a while, you'll get good power there too. You might have to replace the valve springs if you use an X.E. cam...and I also used the roller tip rockers.
  6. Blaze81
    Blaze81 Registered Member
    Feb 19, 2000
    30
    Omaha, Nebraska
    Just more #'s for ya', I've got a Comp Cams PN 12-210-2( I think they called it a #268 cam) in a .040 over 350, stock heads, Weiand intake and Edelbrock 600 CFM carb, TH350 trans and it will spin the 35" tire with 3.73 gears if I ask it to. I get about 9-12 MPG around town(depending on foot-to-pedal pressure) and 14-16 highway(depending on wind direction acting on the big box I call my Blazer).Cam specs are: 218 duration @.050 I&E, .470 lift I&E, 110 degree lobe separation, and 4 degree advance ground in. Also vacuum is no problem, usually about 17-18" at idle without any lope. hope this helps.
    Blaze81
  7. Blazer79
    1,816
    Sounds like a cool setup. How's the low-end torque? Does it sink you to your seat when you take off? (Don't you just love that feeling?) How high do you rev it up? 5000s maybe?
    Go 79s!!!
  8. getsome
    107
    Colorado
    Thanks for the information on the cams. I will admit that a good sounding Blazer should get any red blooded American's pulse going and the cam is the key. The heads sound great but I have new valves waiting for the heads after the machine shop. I have a ugly(to non Blazer owners) K5 and this will be a budget rebuild with very few thrills. I would be interested in knowing your reasons for going with the weiland intake and not the Edelbrock Performer. I have a Edelbrock intake and 600CFM Edelbrock 4bbl. I'll talk to someone at the machine shop and see what they think. Thanks again for the advice and the web sites.
    Getsome
