Need Cam Recommendations for 383 rebuild!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Mar 2, 2003.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I am taking a class at the local college regarding 4 cycle gas engines. As part of it I am rebuilding an old 350 Chevy
    block. I am having the machine shop bore it out so I can make it a 383. I am looking for power and torque not high end speed.
    Any cam recommedations???
    Also, I am installing rebuilt heads.....should I go with roller arms are the basic OEM solid arms???
    Any other recommedations from those that have done this are welcome!!
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Call Comp or Crane cams and tell them what you're looking for and they will recommend something to you. Nothing like going right to the source since they test all their cams in different applications. They probably have some 383 specific applications. Go to their websites and find the phone number or e-mail them...that's what I'd do.
    For the rockers, the full-bearing ones require rebuilding and last about 15,000 miles from what I've heard before they need a rebuild. I'd go with the Nitro Steel ones sold by Comp Cams. Roller tips aren't gonna give you dramatic increases, so why spend all the extra money and time in rebuilds for them? I don't know, it's up to you, but on a DD, I'd just use the normal ones.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    1-800-cam-help is Comp Cams number.
  5. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Call Elgin Cams. Hands down they are the best cam grinder out there period. www.elgincams.com
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That is the exact cam I have in my 388. I would recommend it!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    The specks sounded good, so thats the one I'll get when the time comes. Plans are: 415 stroker kit, that cam, Pete Jackson gear drive, Melling Hi-Vol/Hi-Press oil pump, 8 qrt deep sump oil pan, Wieand Stealth intake manifold, ...ect. Might go to a set of modified Vortec heads, or some Dart 2's. Doug Thorley Headers, MSD 6AL ignition with the MSD Super HEI dist. But all that is in the future.
  8. 4DiggerDan
    4DiggerDan 1/2 ton status
    Feb 2, 2003
    103
    Montucky, USA
    I'd stay with a stock stamped steel rocker arm with either cam recomended, BUT. I'd use the Corvette "grooved" type pivots under the rocker arms and not the stock smooth ones. Come to think of it, on a flat tappet cam in a 383 in a truck, I'd get 8 1:6 ratio stamped steel rockers and stick them in the INTAKEs
    I used a 08-411-8 hydrallic roller in a late one piece rear main block for my 383. Past engines of similar build tell me this makes excellent mid range, good idle (although just a little noticeable.) Works well in a heavy truck with 3.73's or 4.10's on 35's or so. Good flat torque curve (should be over 400 ft/Lbs from 2 grand up to 5 grand with a good head, dual plane intake. and small tube headers.) I'm partial to Comp's stuff. Always had good luck with them... Roller cams are just good /forums/images/graemlins/grin.gif
  9. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Sounds like a cool motor! I'd shy away from the gear drive unless you really want the annoying whine. You will sound like you have a 6-71 blower. Double roller timing set will work just as well.
    I'd also avoid the high volume pump unless you are running loose tolerances that require the extra pressure/volume. A crank scraper and windage tray are cheap and easy ways to control oil windage and make more power.
    Just a few ideas.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Just a few ideas.
    [/ QUOTE ] I do want that gear drive noise. Love that BLOWER sound. Love the way people look when they hear it. Had one in a Camaro, got all kinds of looks.
