Need Carb buying tips
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DzrtRat67, Apr 5, 2003.
  1. DzrtRat67
    DzrtRat67 Registered Member
    May 26, 2001
    17
    A.J. , Arizona
    Present carb is shot. Need to get another.
    Present one is a Carter Quad #1705 9206
    If I get a used/rebuilt one, how do I know what numbers are compatible?
    FYI... This is for our "new" '79 K-5 with a 350 motor, not the '77 that ya'll have helped me out before with.
    yup...got two k-5's now! woo-hoo!
    Thanks!
    Rat
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    get the edelbrock quadrajet. excellent if your looking for a new one. kinda costly though you should here my truck start on a cold day NOW.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Jet Performance Products redoes Qjet for less then the Edelbrock Qjets. If and when I need a new carb I am getting a Jet Qjet carb. The Jet carbs are available in 3 stages of motor levels. You can find them on the Jet website or the Jegs website.
    www.jetchip.com
    www.jegs.com
  4. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    I agree with Hoss, I have a Jet Q jet and it is the best carb I have ever run. Send them in a core and it will be about 300.00 or so
  5. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I would have to disagree i have had nothing but problems from my q jet and have switched to a carter 650cfm which is an exact replica of the edelbrock performer carb which both are made by weber anyways. I would stick with the carter. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/pimp1.gif
  6. DrMaserati
    DrMaserati Registered Member
    Apr 5, 2003
    23
    Oregon
    Now it's my turn to disagree. You have your chronology backwards. The Carter AFB was around for many, many years before Edelbrock started putting their name on it. And a properly set-up Q-jet is an outstanding performer. Great low end torque with the small primaries, and when the huge progressive secondaries open, it will flow far more than your Carter. If you were having problems with your Q-jet it obviously needed some work.
  7. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    just throwing another hat into the ring, there is also the new holley truck avenger carb. but i would put my money on jet
  8. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Anybody know about that new Edelbrock Thunder Series AVS off road carb? Looks like their response to the Holley Truck Avenger.
  9. DzrtRat67
    May 26, 2001
    17
    A.J. , Arizona
    Ok... update time.
    Got a rebuilt (Champion) Rochester Quad from Autozone for $180 with a $55 core. I dropped it off at the shop (they had already taken the Carter off to extract the broken idle-mixture screw (don't ask!)..... they never could get it out...never saw anything like it)
    anyway.... I dropped it off there, waiting for them to call and tell me to try emissions again.
    Rat /forums/images/graemlins/pimp1.gif
