need carb help asap...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StageZ, Jan 16, 2002.
  1. StageZ
    StageZ Registered Member
    Jul 2, 2001
    92
    Los angeles CA
    I just finished building a 388 stroker for my 84 K5...everything is ready to go but the carb... I had an unknown edelbrock on it before(i removed all the smog crap)... but there were too many vacuum lines off it, so I reached in the extra pile and found a Carter AFB... easy to hook up(only one vac line) right? I just checked the part # and found out it's a 600 cfm carb!!! Is that big enough to power a 420 hp 388? I am going to get a Q-jet soon, but with the money I spent building this engine, im broke... does anyone know what carb to use? is 600 enough? or can someone tell me what all those vacuum ports are for on an edelbock carb? can I just cap them? any info will help... thanks in advance....
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    What model number is the edlebrock? I have a 1406(600cfm & elec choke) There are only 3 ports on the front. one of them is for the PCV and the other one of the other two is for the vac advance on the distributor. Im not sure what the other one is for. I only have a line running into the one for the PCV, the other two I have open. Seems to work just fine for me but i should cap them off.
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  3. StageZ
    Jul 2, 2001
    92
    Los angeles CA
    the tag on my edlebrock says 1904(8907 1904 2430)... it seems to have 8 hose ports and one screw in style for the brake booster... i have no idea how much cfm this puts out and if I'm not gonna smog, how many vac ports to plug and what ones I need....
  4. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    You could use a bigger carb IF you're planning on running over 5000RPM. Otherwise, your 600 will do fine. I tried a 780 on my 427 and it seemed to pull pretty good above 4500 but didn't seem to have the lowend torque as it did when I ran a 600 carb. Overall, I like the performance of the 600 better, especially the fuel economy. Besides, how often are you over 4500?
    87 K5, 427BBC,D60 & 14BFF, NV4500, NP208, TSM disc's,
