need charging sys help...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StageZ, Oct 1, 2001.
  1. StageZ
    StageZ Registered Member
    Jul 2, 2001
    92
    Los angeles CA
    When I first got my 84 K5 she needed a new battery... so, I thought I'd just go for it and replace the alt, battery and the starter just to be sure... well... I have had the new battery for about 2 months... and it's dead... So I got another new battery and still I am not pushing the proper voltage(after the battery had time to drain charge)... I'm not too much an xpert on charging systems but I checked the voltage when my engine is running and the MAX(when nothing is on) is around 11.3 volts... when I turn everything on it drops to around 9.1...shouldn't the alt put out 13.4 no matter what condition the battery is in? Is my new alternator messed up? how can I check without goin to a shop? I don't have a good ammeter and am broke so checking amps aint gonna happen... the alt I have is a powermaster 140 amp alt that should push 70 amps at idle... any suggestions and comments will help... should I take it back? (BTW, I checked the resistance of all main power and ground wires, they are goood and have new battery lines) thanks in advance....
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    If it was mine I'd take it back.
    <a target="_blank" href=http://cethern.tripod.com/erics-home-page-and-other-stuff/>http://cethern.tripod.com/erics-home-page-and-other-stuff/</a>
    AMSOIL Dealer # 529948
    Cethern@interfold.com
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    If you dont have the tools to check, then youll have to take the alt somewhere to get it tested. Most parts stores will test an alt for free off a vehicle. ive heard that a bad battery can mess up an alternator but who konws about that
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Take it to a Sears we check everything for $12, including the alternator output under load and not under load, and we also check the diodes.
  5. dyeager535
    26,980
    I assume with the numbers you are posting, you are NOT using the stock gauge for measuring volts?
    9 is really low....but anything over 12 at max load is ok, as long as you are over 12 volts, you are still charging.Since you are nowhere near that, you definitely need to find thge source of the problem.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  6. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    What type of voltage does the alternator put out if you bump the rpms up a little? Some of the "high output" alternators don't really start putting out at idle.
    Smitty
