need column help ASAP!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Nov 11, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I just put in a new turn signal switch in a column that has been apart before. the haynes manual says that there is a thrust washer between the canceling cam and the spring
    but I don't have one and everytime I press the lock plate down It is causing the horn to go off (the first time there has been a fuse in it since I have owned it)
    so what can I use? what does the thrust washer look like?
    does it look like the one in a axle? If it matters it is a non-tilt auto column in a 79
    TIA
    *wink*
    my 79 rust bucket will run over your 2001 chevy 4X4 tahoe plastic wagon
  2. Redfrog
    May 4, 2001
    753
    IL
    Anybody know?
    *wink*
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Where does it say this about the washer in Haynes I don't see that part...?
    &lt;&gt;&lt;<a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>&gt;&lt;&gt;
    Suck Fumes Ford Boy
    I keep trying to lose weight, but it always finds me!
  4. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Nevermind I found it.... I think it's just a washer..... nothing all that special. I'm betting Napa would have it. I couldn't find any pics of the washer from a column but the ones I found from compressors, axles and other stuff all looked like plain old washers a few with little varations for special applications. None of them cost much....
    Suck Fumes Ford Boy
