Need D60 parts! Knuckle's lower bearing and seal!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Oct 16, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Need D60 parts! Knuckle\'s lower bearing and seal!
    K either my local Napa is on crack... or this part is unable to be located. I need to get the bearings on the bottom side of the knuckle, and the seal that goes with it. I've been looking around, and can't find a damn thing. Maybe someone out there has the part numbers? PLEASE?!!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/1zhelp.gif
    -Dan
  2. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Re: Need D60 parts! Knuckle\'s lower bearing and seal!
    I am surprised no one has helped you on this one yet. Do a search for "Kingpin" . Someone posted not too long ago about where to buy and what parts numbers and one person put up all the parts for the rebuild of the kingpins, top and bottom.
  3. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Check nvrenuf's response on this post. Gives a GM part # for lower kingpin rebuild kit.
    king pin rebuild
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dan, if you check out "dana 60" on eBay, you should find some knuckle rebuild kits up for bidding.
    If you can't wait that long, check eBay to see if they list the part number for the kit.
    These kits are Dana/Spicer parts. Your best bet to get the kits would be from Randy's Ring & Pinion. /forums/images/graemlins/wink.gif
  5. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    when i changed mine i took the parts to a parts store with some experience.we took the part numbers of the part.then he called his warehouse and they new what part i needed.there was a number on the bearing and on the seal if you can see them you might want to try that route.most of these parts stores(autozone,advanced auto)don't know there head from there ass.try and find a good mom and pop shop.that's there livelyhood ,not there after school job.
  6. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Spicer part # 706395 Got it from Randy's R&P. Was $22 per side. Has Dust cap,race,bearing,lower seal, and also the upper seal. They must give you the upper because they figure you will mess it up pulling the knuckle.
  7. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Now thats what I'm talking about guys, AND KEITH... you hit it on the head. That is THE number I was looking for. Thanks man! You rock! /forums/images/graemlins/pimp1.gif
    -Dan
