Need Dana 44 10 bolt parts knuckles out (disc conversion)
Discussion in 'Parts & Trucks Wanted' started by 4wheelattitude, Jan 28, 2006.
  1. 4wheelattitude
    4wheelattitude 1/2 ton status
    Aug 5, 2005
    145
    central Illinois
    I'm needing to convert to disc brakes on my old 70 GMC. I would like to get everything and including the knuckles out. I'm not working right now (off because of work injury) so if I could get these cheap I would appreciate all the help I can get. I'm just south of Springfield, IL. Please PM me or email millertyme88m@peoplepc.com
    Harry
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I'll have a 6 lug axle coming out of my '85 GMC Jimmy shortly... new brake pads but the rotors were not much to speak of. If you can't find anything closer I could toss the rotors and ship the rest fairly cheap. I'd want $50 for the knuckles out plus shipping.
  3. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    The price is right! Where are you located?
  4. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I've got a some parts listed HERE.
  5. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    Do you have the knuckles? ?$
  6. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I'm keeping the knuckles because they are flat tops. I'd sell you my other knuckles, but I won't be doing crossover for quite a while. I just happened to get a deal on these 2 axles. I can check with the guy I bought these from, I think he had another D44 lying around. :D
    Rick
  7. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    Thanks, I realy need to move the truck asap
  8. kennyw
    Jun 9, 2002
    13,224
    94
    I'm in WA state. Don't know that I'll be getting the axle out within the next couple weeks though. Leaving for MN next weekend and work 200 miles from home right now so I'm gone during the week... so it will be a couple weeks before I have the time to get it out.
  9. 69TowRig
    69TowRig 1/2 ton status
    Dec 20, 2004
    288
    Raleigh, NC
  10. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    Thank you 69TowRig for the help.
  11. mrk5
    Apr 20, 2004
    12,346
    1,049
    Northern Colorado
    I have a set of knuckles off a '76 D44, not flat-tops. Just took the axle out of my truck a month ago. The ball joints seem fine, but of course no guarantee.
    $25 for both+the ride.
  12. 69TowRig
    Dec 20, 2004
    288
    Raleigh, NC
    No problem. I converted my '69 K5 last year, what a PITA. Right after I had bought the knuckles, hubs, rotors, etc I started finding complete axles. I wish that I had waited for a complete one, because all those little parts add up after a while. I did add a power booster, rebuilt master, and disc/drum proportioning valve to the mix, new hard lines and flex hoses too. But overall it would have been easier if I had a complete one to start with.
    It's a LOT of work. In the end it was worth it, the truck has brakes to stop a train now, but all that time into it was a drain on my energy (and funds).
    One thing to note, if you do the disc swap with 73+ knuckles but keep the original outer shafts you will find that the snap ring that used to retain the outer axle shaft will no longer fit. You will need two 7/16-20x1" bolts and fender washers to retain the axle shaft. I can send you pics if you want them. It seems that the disc outer shafts are about 1/4" longer.
  13. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    Thanks for the info. I did notice that the shafts were shorter, but didn't know what to do about it. I would apppreciate the pics and any help I can get.
  14. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Would it work to use the 73+ outer shafts with the swap?
  15. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
  16. 69TowRig
    Dec 20, 2004
    288
    Raleigh, NC
    Yes, that would let you keep the snap ring instead of doing this:
  17. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    Hey, Thanks for the pics. 69TowRig
  18. 69TowRig
    Dec 20, 2004
    288
    Raleigh, NC
    You know what, I remembered something, those 73+ outers might not work unless spicer sells a hybird joint for the front axle. 72-earlier used a smaller u-joint than the 73+.
  19. 4wheelattitude
    Aug 5, 2005
    145
    central Illinois
    Yea. I measured the other day after getting your post
