Need drag link end size for WFO high steer arms?
Discussion in 'The Garage' started by stallion85, Sep 4, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I tried calling Trevor, but he is not in yet. I was wondering if anyone knows the size by chance off hand?
  2. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    standard 1-ton stuff AFAIK... did they make different sizes for 1 ton chebbie trucks?
    j
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    The web site says the draglink end is larger than the tie rod end. I need the threads to be 7/8" to fit my draglink and the taper shank of the ball joint to be a step bigger. When the standard end is in the shank goes all the way through the hole to where the ball joint would bever be a able to be tightened.
  4. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    order up a drag link end for a 3/4 ton, rather than a tie-rod end, and you'll have the right part.
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Draglink ends are different for crossover steering from what I have found. A standard draglink end will definitely not work in this application.
