need drive line specs for 74 blazer with 4" lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by highlow, Dec 12, 2002.
  1. highlow
    highlow 1/2 ton status
    Oct 8, 2002
    124
    need drive line specs for 74 blazer with 4\" lift
    I bought a 74 blazer with a 4" lift and it came with no front drive line. What length do I need for a 4" and a 6" lift on the front drive line? Also this thing is lower in the front than the back what can I do to make this thing level or slightly taller in the front?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: need drive line specs for 74 blazer with 4\" lift
    ORD's 1" zero rates for the front will give you 1" lift /forums/images/graemlins/grin.gif
  3. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    i need a 29" shaft for my 73, but the best way to check is to measure the distance between the yoke on the axle and the yoke on the t-case, that will be the length you need
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I needed a 43 inch shaft... i think.. for a 6 inch w/14 bolt... /forums/images/graemlins/shocked.gif
  5. blazer74
    blazer74 Member Premium Member
    Oct 18, 2001
    1,157
    74
    Brighton Tn
    If your sure you have a 4 inch lift stock shafts should be fine. I've been running mine that way for 15 years, no problems. But the Best thing to do is measure from flange to flange and have them made to the correct length . If you can, go with a cv in the rear. If you have more than a 4 inch lift you will need longer than stock.
