Need education: '96 S10 tranny/t-case?
Discussion in 'The Garage' started by big94gmc, Sep 10, 2005.
  1. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    What tranny and t-case would come in a '96 S10 ZR2 with the 4.3 Vortec? :o
  2. big94gmc
    Sep 1, 2004
    3,651
    No VA.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    4L60E and a np233 (electric shift np231)
  4. FreedomIsntFree
    FreedomIsntFree 1/2 ton status
    Aug 23, 2005
    124
    DFW, TX
    Ok Kreskin! What came in my 1974 K5 1/2 ton with a 350? I don't know how to tell t-cases. Is it a 203, 205 or 208? :dunno:
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    74 was an oddball year. You could have a Turbo 350 with an NP203, or a NP465 with an NP203. If I remember right, that was the only year that GM offered the manual trans with a full time t-case.
    208's weren't even made in '74, so the only way to have one of those under it would be if someone did a swap. :rolleyes:
  6. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    A'ight, awesome.... Now, could someone give me a ballpark figure what an NP233 would sell for, in good/operating condition?
    And could someone also give me a ballpark figure as to what a 2-month-old rebuilt 4L60E would sell for....?
    Does a 4.3 has the same bellhousing bolt pattern as a 305/350? (In other words, would this tranny work behind a small block?)
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Yes it will work behind a small block. All 90 degree V engines from Chevy (4.3 V6, small block, big block) have the same bellhousing pattern.
    Used to be S10's got transmissions with less clutches and things to make the case smaller so it would fit in the smaller trucks. Might want to check and see if that's still true.
  8. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    TTT
    Anymore info for me?
  9. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    a 233 with the electric shift motor should go for around $125. The 4L60-E you have is the newr version with a removable bellhousing. If you still have all the paper work on the rebuild figure maby 500-700 dollars. Take a look on ebay that will help give you a better idea what these things are going for
