Need eletrical advise..Temp guage related
Discussion in 'The Garage' started by ftn96, Aug 17, 2002.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Got a dead temp guage. Doesn't seem to be running hot, but none the less...Not good. I got this damn $40 multi-meter, but I'm no electrician and I dont want to have to start the plug and prey process of elimination. So.....
    How can I test to see whether the guage, sending unit or wire is the culprit?
  2. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    If your gauge never gets off of zero, try shorting the sending unit wire to ground. It should peg the gauge at the max temp reading.
    If that works, it's your sending unit. If it doesn't work, you may have a busted or loose wire, and/or bad sending unit.
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok. Good idea. But this particular "situation" has a 2 wire plug. So could I just have the ignition on and bridge the 2 plug terminals together?
