NEED ENGINE ADVICE ASAP!!!! PLEASE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5_73, Oct 28, 2001.
  1. K5_73
    K5_73 Registered Member
    Feb 5, 2001
    53
    Wichita, Kansas
    We're putting a 383 in my friends K5 tonight and some weird crap is going on. We started it and it ran for about 3-5 seconds and the rubber seal blew out from the oil filter and oil sprayed everywhere. We figured it was a bad filter and put another one on and the same thing happened. What could be causing this? I've never heard of this happening before on ANY motors. Thanks for the help.
    Stupid hurts
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    its building too much oil pressure , some oil passage must be clogged or sumthing
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  3. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> that's about it.
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If you have the oil bypass valve blocked off as some people do that will cause that.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=) [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/chevyracing>http://community.webshots.com/user/chevyracing</a>
  5. K5_73
    Feb 5, 2001
    53
    Wichita, Kansas
    OK, dumb question, but where is the oil bypass valve? Also, since the new oil pump had been sitting in my garage for a few years, and I didn't check the spring before I put it in, I'm thinking I might need to changed the spring to the other one that came with it. I'm hoping it's nothing serious...the last thing I need is more problems.
    Stupid hurts
  6. Kajun_K5
    Kajun_K5 Registered Member
    Jul 9, 2001
    48
    Lafayette, Louisiana
    Does it have an cooling system for the oil?
    Why the hell not?
    <a target="_blank" href=http://www.geocities.com/daniel_ray_deville/my_blazer.htm>http://www.geocities.com/daniel_ray_deville/my_blazer.htm</a>
  7. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    The oil filter by-pass valve is the little thing-a-ma-bob that the oil filter screws onto. It is held on by two 7/16 bolts. There will be a little flap on it that should move up and down because there should be a spring behind it. Sometimes people take the little spring out, thread the hole and put a plug into it to get a higher oil pressure reading.
    That is the simpleset (&lt;----spelling) thing to check. Just take off the oil filter and thar she blows.
    John
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Most likely, the relief valve in the oil pump is not functioning. There is a small orifice that can get plugged, and then you will get full pressure.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  9. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    Tim,
    I thought he had full pressure actually too much pressure.
    John
  10. Blazer1970
    1,600
    Old Mission, MI
    That's what I mean. If the orifice is plugged, the relief valve will not relieve the pressure, and you will get as much pressure as the pump can deliver (a lot). It will eventually ruin the cam and or distributor gears, or break the oil pump drive shaft.
    Tim
    87 Burb 4X4 350
  11. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    Gottcha.... If that engine is blowing the rubber seal off of an oil filter that is the minimum of damage going on.. I hate it when that happens...
    John
  12. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    How much RTV did you use?? It is not unusual to get that stuff jammed in the oriface that houses the pressure relief valve for the oil pump. That is where I would start.
  13. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Definitely replace the oil pump. This is usually the cause for oil filter explosions! JT
  14. tlarsw
    tlarsw 1/2 ton status
    Jan 12, 2001
    270
    Cameron, NC
    Did you ever figure out what was causing the problem? We encountered the same thing this weekend with a 350 we installed.
    Thanks for any info.
    1986 K10 TPI350/NV4500/Gen2 Doubler/D60(ARB)/14FF(Detroit)/4.56 gears
  15. K5_73
    Feb 5, 2001
    53
    Wichita, Kansas
    Yeah, of course it had to be the most difficult thing. The darn check/pressure valve was stuck in the oil pump, so I had to pull the pan and pump, but it's great now! My buddy said that I left two 30 foot black marks in front of his house when I took off! Sweet
    Stupid hurts
  16. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I heard that when there is a bunch of dirt on the pavement it makes it alot easier to lay rubber. Dumping the clutch at 19000 RPM helps too. [​IMG]
    '73 K5
    Chevy good...Ford bad
  17. K5_73
    Feb 5, 2001
    53
    Wichita, Kansas
    If you would took a bath once in a while, the street wouldn't be so dirty, hehe. 19000 rpms, wouldn't that be nice?
    Stupid hurts
