Need engine compartment pics please
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by LKJR, Aug 18, 2002.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    trying to figure how to mount my On Board Air on the Passenger side, but the head dosen't have a bolt hole in the front like the drivers side does (only one instead of two) wondering if others had the same setup or if anyone had ther alternator mounted on the passenger side. Where did the factory A/C mount? thanks
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    LKJR,
    Even though you don't seem to care for my ideas much in the past, I will try to help. Locate an alternator bracket for early heads without bolt holes (usually 67 or older) that connects to the first two exhaust bolt holes and that should solve your problems. Summitt has them in chrome or standard old steel for cheap. If you run headers just use a long stud and a spacer and that will solve your problem.
    John
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    hmmm, thought crossed my mind, maybe I"ll look into that, thanks, sorry if I have came across and not wanting your ideas, don't know where / when but I apologize for that, I"m always open to ideas, if I don't use it directly sometimes it will spark a spin on something else.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i will take a picture of mine. i have the alternator on the passenger side. my 350 came out of a 75 blazer. i also have all my running on one 58 inch v belt. i have p/s, alt, harmonic, and fan.the only thing i had to do was tack weld a washer onto the power steering pulley so that it would space out an 1/8th inch. you might not even have to do that. hope it helps
    nathan /forums/images/icons/grin.gif
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i didnt get a chance to get the pics. i will try again tonight.
    nathan
