Need Exhaust for 85 Suburban ANY IDEAS?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BURBIN406, Nov 28, 2002.
  1. BURBIN406
    BURBIN406 Registered Member
    Nov 17, 2002
    17
    New Jersey
    I am in need of a dual exhaust system for my 1985 Suburban. When I installed the 6" lift, my front driveshaft now hits the y-pipe and can't be installed. I am interested in a manifold back system since my truck only has 72,000 original miles on it. Any ideas are greatly appreciated.
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    i would go to a performance exhaust shop and have them build you a complete system. i'd go single 3" pipe hi-flow cats (if you need cats) and a flowmaster 50 series muffler. /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  3. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I ran into the same problem you now have. If you must run cats then I'd do what muddysub suggests. If you can go without cats, I had true duals run from the manifolds back and out each side of the truck. The shop used 21/4" pipe and flowmasters. They only charged me $350 which I thought was pretty good. If your existing exhaust is still in good condition, have an exhaust shop make a new RH pipe for the Y-pipe that will not be in the way. That would only have cost me $75 but I needed new exhaust anyway otherwise I would have gone with that route. Just a suggestion. /forums/images/graemlins/burb.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If you're replacing the exhaust system, why not go to headers ??? I was a die hard Hooker Headers fan, but now I want Doug Thorley TRI-Y headers !!!! Gotta love that TRI-Y for the torque, and how they're made for 4 Wheel Drive trucks !!!!!! For duals, I'd say 2.25" exhause with flowmasters, and Meg's exhaust tips. I like 40 series mufflers, but I like them loud !!!!!!! /forums/images/graemlins/thumb.gif
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    If you don't want to spend too much, ask an exhuast shop to lower the Y-pipe...they shouldn't charge too much, but, if you want to go dual, now's the time to do it.
    I'd get Afterburner headers and run 2.5" pipe with flowmasters.
    Midas should only charge around $350 to do the whole thing for you. By law, you have to use as many cats as the truck came with...in your case, you have to run one on one side, but not on the other because yours came stock with only one cat.
  6. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    well i just finished installing an exhaust on my 85 sub with 6" lift this is what i did..
    1. doug thorley headers summit part # DTE-364Y-S
    price = $369.00
    2. catco universal cat summit part # CTO-6007
    3" in 3" out $53.69
    3. flowmaster series 50 SP# FLO-53055
    3" in 3" out $91.95
    4. summit 3" aluminized pipe SUM-640030
    2 pieces 4' each $26.78
    5. To make the Y-pipe i went to napa and bought various elbows and some 2.5" pipe. i saved the receipt some where /forums/images/graemlins/confused.gif
    if you think this what yo might want to do, i'll find the receipt with all the part #'s and take some picks of my system.. let me say that the thorleys fit great and summit rules... and the pipe sections i got from napa were very easy to make work if you have a welder a drill press and a 2.5" hole saw....
    ps the thorleys i got are smog type... good luck /forums/images/graemlins/thumb.gif
  7. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    On my '85,I am running Thorley's Tri-y's and a JC Whitney dual kit. The pipe was on sale for $110. I am using the Summit fully welded mufflers. I think they are the same as Flotech's afterburner muffler. I ran the pipes out the back since I have barn doors. Ordered a couple of sticks of 2.25" from Summit when I ordered the mufflers. Don't have to worry about smog here, so no cats. /forums/images/graemlins/burb.gif
  8. BURBIN406
    Nov 17, 2002
    17
    New Jersey
    Thanks for all of the great Ideas!
  9. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    if you only half to run 1 cat then it would be kinnda nice to run a H pipe with the cat in the middle right? There for the cat wouldent hardley do anything right?or im I just trying to beat the law to hard /forums/images/graemlins/confused.gif
  10. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    You could do it...but they could get you because it's not effective. Call an inspection place and ask if it matters where the cat is on the system...if not, do it!
