need expert advice
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tom, May 28, 2000.
  1. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    I want a reliable stick shift blazer. Reasonable to drive on the road and capable on the trail. I want it tough enough to drive me home every time out. It must be stick shift, with modest size tires (33's or 35's). How do you think I should start, (1) SM465 with tall axel gears and a deep reduction transfer case, or (2) NV4500 and 4.11 or 4.56 axels and standard transfer case? What's your vote? Thanks.
  2. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I have a '73 with the 465 trans 205 transfer,dana 44 front,12 bolt rearboth with 4.10 gears and detriot lockers.I drive this all over cruises great.It is alittle loose in corners because I don't run a swaybar.I have 33" swamper TSLs.I do break stuff sometimes.Usually U-joints easy to fix.I am planning on doing the doubler from ORD.Brady
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    If you post what are the gear reductions of each tranny and what engine you have we could help better.
    <font color=black>//////
    What the heck!...Drive it like gas is $0.50/gal!!!
    </font color=black>[​IMG]
