Need extended brake line recomendations.
Discussion in 'The Garage' started by y5mgisi, Mar 25, 2004.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I just put a 4" lift on the burb and now i need new brake lines(i knew i would) So i need to know what you guys would recomend(like what brand and stuff) They have to be as cheap as possible, work with the 4"lift and not be crappy. Also all im getting is the fronts for now. /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    skyjacker lines are NICE
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  4. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    Pro Comp has a set of stainless steel braided lines for a 4-6 inch lift I don't have the part number but I have them on mine and they are good quality they are made by earl's so they are good stuff....Jason
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Really? I have those. Someone told me they would pull out and fail. Hmmmm....Earl's are good hoses. Interesting /forums/images/graemlins/thinking.gif /forums/images/graemlins/k5.gif
  6. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    The ones I have are made by Earl's and I was recomened those by someone here I don't remember anymore.....Jason
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I am using pro comp lines as well and no complaints yet.
  8. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    NAPA lines. Theres pics of them installed on my website below. Fronts were $16/ea rear was something like $14
    Work fine /forums/images/graemlins/thumb.gif
  9. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I run the Napa lines as well. They are 25 7/8" long and is plenty on my 5" lift.
  10. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I have those too. I still need to put them on though....
    justin /forums/images/graemlins/burb.gif
  11. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    I also have ProComps... been runnin em for 2 years or so I guess... not a single problem.
    j
  12. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What I said was my braided SS lines sucked. I had the Super Lift lines. They are bad, and after dealing with them I would never deal with a braided SS line again.
    Mine didn't pull apart either from flex, the line presure in the hose blew them apart at a fitting.
    I now run the Napa extended lines. I agree. Best $18 each I have spent. Lifetime warranty too.
    Harley
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I had mine custom made to my specs with special retainers and all for around $90 on all 3 lines. But, for most rigs (like my son's and the family K5) I would use the suggested part numbers.
    Just wondering, are there off the shelf (cheap) longer lines for the D44 (or have I missed that somewhere in this thread).
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I think you can modify the 38872's to fit a D44. I know Matt had lines that are for a 10 bolt on his D44 with some grinding I think. Worst you could do is use a set of 10 bolt calipers on your son's D44 and get the 38872's.
    Harley
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thanks harley, I remember your old post . I just assumed flexing would of made it weaker and your hose burst sometime later. If these are really by Earl's do you think they may be better?
    Thanks,
    Paul
  16. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    There was no way I ever got close to pulling on my hose when it blew out. I still had only 2.5" lift, 32's, and was still running factory dual shocks so I know the shocks would have limited the suspension long before the brake line ever would have had any chance at getting tugged on.
    Harley
  17. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Well got them on...You wil need to grind the hoses to make them fit your 10 bolt if it has the "ring around the mounting point" on the caliper. They do work though and im glad i got them. A fraind (muddytazz)says that he had to ream out the bolt hole for his d44 line mounting bolt(at the caliper). So any who any more questions, let me know /forums/images/graemlins/cool.gif
  18. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Guys, I have not had time to get these on the web site yet but they are available. Front extended (24") brake hose for D60, D44 and 10 bolt axles.
    Rubber hose @ 33.00 each
    Stainless hose at 38.00 each
    Shipping to lower 48 states @ 8.00
