Need extended front drive shaft for 4in lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Apr 28, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    Do I need one? My friend just lifted his short bed chevy 4in, and says he needs one. Is he full of it?
  2. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    nah man, i just lifted mine last week, all ya need to do is drop the transfer case, and that only takes 5 minutes.
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    You don't need either shaft lengthened with 4''. I have 6'' and both stock shafts. If you lower the T-case it will help eliminate vibrations in the rear shaft by improving u-joint angles, but at the same time it will make the angles for the front shaft worse. I am just living with the lowered T-case untill I can afford a c/v shaft for the rear.
  4. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    Blazinaire... Driveline service in West Sacramento builts CV shafts for 300.00. Just to let you know. I had to have my rear driveshaft lengthened 2" with my 4" lift. Even with lowering my transfercase 1" I also had to shim my rear blocks in order to get my angle right. They charged me 77.00 to lengthen the driveshaft and balance it. It is smooth now though.
