Need fan shroud for 77 k5 in AZ
Discussion in 'Parts & Trucks Wanted' started by levib, Aug 29, 2005.
  1. levib
    levib Registered Member
    Aug 30, 2004
    68
    Avondale, Arizona
    title says it all
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    for what size radiator, and how large blades opening diameter
    etc.
    i may have one
  3. blublaz
    blublaz 1/2 ton status
    Nov 6, 2004
    145
    Tucson AZ
    shroud
    if one from an 85 will fit let me know ....im in tucson
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    That won't work.
  5. kennyw
    Jun 9, 2002
    13,223
    94
    Need to know what motor and what size radiator. There are 2 different height's. Then 350's have a different length than 454's... I have found that Chevy Duty sells new reproduction fan shrouds nice and cheap. Bought a new one for a 73-80 with a 454 for something like $15-20 from there..
  6. levib
    Aug 30, 2004
    68
    Avondale, Arizona
    Well the motor is a 400 and I measured the part of the radiator the shroud covers at 28 x 20 1/2. The reason I need a shroud is the previous owner used a 3 in body lift and removed the shroud. I dont know if I would need a modified one because of that?
  7. kennyw
    Jun 9, 2002
    13,223
    94
    With a 3" body lift you need to lower the shroud by 3" for it to line up right :doah: Or think about removing the body lift and run a stock shroud. Might be better off building a custom shroud than trying to make a stock one work.
