Need Fast D60 Help! Inner Stub Shaft snap ring not going in!
Discussion in 'The Garage' started by zakk, Jun 13, 2003.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    HELP!!
    title says it all, I have the stock Spicer hubs, and the end doesn't seem to seat to allow the snap ring to get on the stub shaft.
    suggestions?
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Get a pry bar behind the u-joint and push it out toward's the hub. /forums/images/graemlins/grin.gif
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    don't tempt me! seriously now?
    how the F^&k does this thing work?
    Zakk and M.
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hey Zakk...He is serious dude. /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
    How far from being able to get the ring on are you? Is it just a tiny little bit? If it is, stick a pry bar or 12" crecent or something behind the axle shaft u-joint and pry out. There's usally quite a bit of "slop".
    Why did ya have it apart in the first place?
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    /forums/images/graemlins/blush.gif it worked! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Sweeet! Zakk gave up and listened he figured we should try it, it worked perrrrrrrrrrfectly.
    Thanks guys!
    Marcus (posting from a laptop using the wireless network while Zakk is under the truck swearing with the pry bar. .. . .)
    edit- two wordds for laptop makers: 'backlit keyboards'
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Sweeet! Zakk gave up and listened gave up figured we should try it, it worked perrrfetly.
    Thanks guys!
    Marcus (posting form a laptop using the wireless network while Zakk is under the truck swearing with the pry bar. .. . .)
    [/ QUOTE ] No [naughty word] /forums/images/graemlins/smirk.gif
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Now how much grease should he use to pack the bearings?
    My answerf was quite abit. . . can anyone confirm?
    thanks
    M.
  9. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    As much as You can pack in there, I think I got two tube's in each side of mine.
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Well...
    Pack them till they are full. /forums/images/graemlins/rotfl.gif
    I use the old fashioned, messy, glob of grease on the palm of my hand method. /forums/images/graemlins/thumb.gif
  11. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Well...
    I do that first with the bearing's, then use a pistol grip grease gun, and fill er full! Then install the outer bearing. /forums/images/graemlins/grin.gif
  12. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    thanks
    M.
    <font color="green"> I used damn near an entire tub on each side. Them 60 hubs are BIIIG! </font>
