Need flywheel for 6.2L diesel
Discussion in 'Parts & Trucks Wanted' started by Stephen, Jan 20, 2002.
  1. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    That pretty much sums it up, we're dropping a 6.2 in a work truck and need a flywheel to bolt it to the SM465. As far as I know (which may be wrong) the clutch should still work, just need the flywheel.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    a regular gas 350 flywheel wont work ?
    pics page
    <a target="_blank" href=http://www.imagestation.com/album/pictures.html?id=4292257869&show_all=1&start=1>http://www.imagestation.com/album/pictures.html?id=4292257869&show_all=1&start=1</a>
    always gets me home K10
  3. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    no a gas flywheel will not work. i just finished that swap last week. the diesel ones are 139 tooth. there is a discussion in the diesel forum about this. heavychevy had said that u can not use a 1992-2002 6.5 turbo diesel flywheel because the clutch springs will rub on the flywheel bolts. i guess that is true for centerforce clutches but as far as i can tell u at has worked on my truck with the cheap auto parts clutch (w/lifetime warranty) without any rubbing. I got my "new take-out" flywheel from Diesel Depot in georgia 1.800.553.8192 for $150. they also do tons of the same swap- automatic(th400/700r-4) to SM465 with 6.2s.
    nick
