need front lift help
Discussion in 'The Garage' started by PsychoticDeadGuy, Aug 27, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i am getting ready to put in a some ord zero rates in the front of my k5 with stock steering. it has 4" rancho springs on it with long enough brake lines but is there any other things i need to look out for with the extra inch? will all my steering components clear eveything? i have to be able to do this without getting into other problems because this is my only rig and i need to go to school everyday.
  2. PsychoticDeadGuy
    Jan 8, 2005
    753
    anybody? i would really appreciate some help ASAP
  3. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    do you already have the raised steering arm?
  4. 74757685k5
    Nov 13, 2004
    258
    montana
    the stabilizer prolly wont reach anny more
  5. PsychoticDeadGuy
    Jan 8, 2005
    753
    i am not sure. i bought the truck with the rancho lift already installed. how would i tell?
  6. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    Stabilizer? you meen swaybar right? Anyway you got a 5 inch lift now so all that cheapy get out of jail free stuff is history. What do I meen, you say? Well extended break lines and stearing correction must now be installed. If you are dead set on not rolling like a boat through corners you will need that handy dandy sway bar disconnect/correction kit our mentor Steve at ORD sells. Oh and dont forget longer u-bolts, and if you got a dana 60, longer bolts or studs for the passenger side spring perches. Those zero rates rule! Enjoy the extra clearence!!!
  7. PsychoticDeadGuy
    Jan 8, 2005
    753
    i have everything addressed except the driveshaft and the steering. that is what i need help on. what will be needed to correct the steering and will the driveshaft be fine or no?
  8. PsychoticDeadGuy
    Jan 8, 2005
    753
