Need front shaft... 1978 th350/203 to a 10 bolt f
Discussion in 'Parts & Trucks Wanted' started by twenty_below0, Aug 27, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    I need the front shaft mine is stock and sloppy side to side
    where they slip together, so if you have a tight stock one it will work or aftermarket for a 4" lift. Or a spacer might help tighten mine up. Throw it at me need this before winter!
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    75 bucks(just a number so counter offers is fine) to your door. stock off a 74 350 th350 203 d44. same u-joint so it should bolt up. send me your measurements just to be sure on length.
    grant
