need fuel tank info please.
Discussion in 'Other Rides' started by sweetk30, Mar 8, 2005.
  1. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    my moms resto of a 73 mustang is ready for the fuel injection system. i need a good way to plum the return line to the tank. what is the best way to do this. i have a new tank that hasnt had gas in it yet. and the sender has been out for about a year. so if i need to weld a part on i can do so. i have a state and government certified welder person at my disposal for this job if needed. thanks for the help.
  2. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I wanted a drain plug for my fuel tank and so I took it to a radiator shop and the soldered a fitting from a radiator and installed a plug in it . i also kow a fell who used the charcal canister line and use it for a return line . Hope that helps
  3. sweetk30
    Nov 1, 2004
    25,554
    548
    i need to run a return line from the efi system, to the tank. it has only 1 line on it. its a single line system now from factory.
  4. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    buy a sending unit from a fox body mustang, they have return lines, the newer body mustangs don't have return lines.
  5. sweetk30
    Nov 1, 2004
    25,554
    548
    but will that sender work with my 73 tank and fit the hole . this is a edelbrock pro flow setup with return line from rail.
  6. sweetk30
    Nov 1, 2004
    25,554
    548
