need glass install tips
Discussion in 'The Garage' started by jones, Jul 4, 2004.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    installation instruction needed for pwr windows and also rear slider on truck.thanks!off to the fireworks!!!yeah /forums/images/graemlins/peace.gif
  2. jones
    May 17, 2004
    379
    IONIA,MI USA
    c'mon,guys!someone has got to know this.or should i take it to a glass shop?anyone?hello! /forums/images/graemlins/dunno.gif /forums/images/graemlins/ears.gif
  3. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Rear slider, easy. Lay slider down. Put gasket around it. Use 1/4" nylon rope, hook tool, and glass cleaner as lubricant. A second person on the outside holding the glass and slightly pushing will help. Once you get good, you can do it yourself in 5min, or less. (Note: If your gasket has chrome or rubber "interlock", toss it and get a new gasket without. They look ugly and don't install as easy.)
    What specifically is your "power window" dilemma?
  4. jones
    May 17, 2004
    379
    IONIA,MI USA
    [/ QUOTE ]thanks for the reply.i got a pair of rust-free doors from the junckyard but the drivers side pwr window has been shattered(side-impact,i'm assuming)so i need to swap in the good glass from my truck.does the vent window have to come out?2)what's the bolt in the door jam for?3)how does the slider come out(it's not broken but rattles badly.very annoying)?more appropriately:glass removal/install.tips.thanks.
  5. DougK20
    Feb 18, 2003
    384
    Boise, ID
    Not totally, but I do loosen it up really well.
    Guessing it's holding the track on that side. I would loosen it, but not remove it.
    how does the slider come out?
    Push gently from the inside at the top corner and slowly work it out. If your gasket has an "interlock" on the outside, pull it out first before pushing out the slider.
    Odds are, the doorglass from your rig is glued into its track. Which means you'll have to re-use the track or complete regulator. The odds of breakage are very high if you try to remove it from the glue. If it's not glued, use a razor to cut the rubber holding it in.
    If there is shattered glass glued into the track of the new door, use a drill and drill bit (the width of the track) and drill it out. Wear eye protection! You will need to glue the new window into the track with windshield urethane. Good Luck! /forums/images/graemlins/thumb.gif
