NEED HEEP......How do I get the bearing out (14 Bolt)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Sep 12, 2002.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I took the hubs off the 14 bolt axle and was able to get the inner bearing out by just removing the seal. I turned the hub over to take the outer bearing and observed there to be a snap ring holding it in. I thought once I removed the snap ring the bearing would just fall out; not the case. I pounded on the other side to get it out but, no luck. So, how do you get these things out?
    Thanks,
    Charles
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The bearing and race have to be pressed out together.
  3. BlueOx
    Aug 6, 2000
    239
    Houston, Tx
    Thats what I thought. Looks like I'll be taking it to the drive-line shop.
    Charles
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    all you need is a brass drift and BFH. done mine this way and no probs.
