Need Help, 14ff wheel bearing ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TrcksR4ME, Mar 7, 2002.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Need Help, 14ff wheel bearing ?\'s
    I am in the process of getting a 14 bolt ready to install under my Blazer. I installed new races and bearings and have the drums back on the spindles. Also have the special socket for the adjustment and lock nuts.
    My question is how tight do the adjustment nuts need to be? The Haynes Manual says 50ft-lbs and then back the nut off until the nut slot lines up with the keyway. When I took them off they were not that tight and I want to make sure im reading this right. This is my first time doing it, so I have nothing to go off here.
  2. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    Re: Need Help, 14ff wheel bearing ?\'s
    Wheel bearings have been nothing but problems for me. Do it right the first time. If the manual says to do it than that is what you should do.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    zero preload
    you torque it up tight to seat the bearings then back off
    then pretty much hand tighten while spinning hub til it doesnt move in n out
    basically til contact but no torque on them
  5. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    hmm, i torqued to 50 and backed off some like it said in book, but i dont know if it was enough. Already put it together, but can redo that pretty easily. The book sure is not clear, so seat them and then back the nut off and tighten it up just past hand tight or so?
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I do mine just like the Haynes manual said and had no problems. I also talked to Roger about it and he said that is what to do also. Just make sure you spin the drum while you torque them.
  7. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Thanks for the info, I did spin and tighten at the same time. Its just one of those things where I feel like I must be doing it wrong cause its my first time...lol
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I felt the same way and that is why I questioned Roger about it.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you should be able to feel the hub/drum play as you hand tighten the nut
    just tighten it up until the play is gone but before the hub feels like it drags as you try and rotate it.
    these axles are pretty forgiving, so if it spun freely and didnt move in n out you are most likely in the ballpark
  10. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I figuered I followed the book instructions closely so it is probably ok. Seems hard to tell drag with the drums being so heavy(meaning I didnt feel a noticable difference), but once its under the truck I'll check it again then and maybe adjust the nuts since it is so easy to do.
  11. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    If you did it the way the book said to do then it is gonna be ok.
    Never lost a wheel yet due a bearing failure or a leaky seal doing it that way.
    And I have done more than one or two.
    Even semi hubs are set up this way.
    Did ya fill the hubs with lube before buttoning it all back up?
  12. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    For the rear W/B, it's not as critical of an adjustment as it is with the front W/B (steering axle).
    I just tighten the nut down while spinning the drums. Snug, but deffenetly not 50 ft/lbs.
    Then back the nut off, and spin the drum.
    Then hand tighten the nut, I usualy don't even use a rachet, just the socket.
    The back the nut off to alighn the key ways.
    I've never had problems doing it like this.
