NEED HELP 2 post starter and a 3 post starter
Discussion in 'The Garage' started by adamforsythe, Jan 22, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I just got a new starter that is 3 post. My old one was only 2 post. what does that extra post for?
    Adam
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You talking about the electrical posts on the solenoid?
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Its an unused post, you just use the battery post and the post that is closest to the motor(can't remember the letter that is next to it off the top of my head).
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I just got done installing a new starter with 3 post. Well when I try to crank the engine it sounds like it just sparks.
    What is going on?
    Adam
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Your battery wire goes to the big post like normal, then all your ignition system wires (which I believe there is 2 wires - at least there is only 2 on mine) goes to that 1 post that is closest to the engine block. The post that is closest to your tire is not used.
    And make sure no wires or connections are touching anything but what they are suppose to be touching.
  7. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    There are two wires running to my pos post (battery and another wire.)
    Then there is the (-) wire that is connected to the post right by the block.
    Adam
  8. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    The battery is dead but it should not make it sound like it is sparking. I tryed jumping the truck and nothing happened.
    Adam
  9. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    what should I check. I know my wiring is right.
  10. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Well I just found out what happen. Napa sold me a junk starter. Sucky thing is it is going to snow like 2 feet this weekend and napa is not open in tell monday.
    Adam
