Need help! 3.625" or 4.625" Backspacing?
Discussion in 'The Garage' started by 91GMCSuburban, Jun 4, 2005.
  1. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    which should I go with? 3.625" or 4.625" Backspacing.
    15x10 wheel w/either
    1) 35" on 4" lift + 2.5" reverse shackle, extended front shackles. So I guess about 6" total.
    2) 33" on 4" lift
  2. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    C'mon guys, I need help.
  3. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    3.625 on 8" wide rims
    or get 17" wheels in 9" wide.
    Edit:
    FWIW the 17" wheel comment was so you wouldn't run into the problem I did with having to grind the hell out of your calipers when you go to 8-lug after breaking the 1/2-ton axles. It will save you $$$ in the long run only having to buy new rims and not rims and tires.
