Need Help A.S.A.P.!!!!
Discussion in 'The Garage' started by Suffergauge, Aug 27, 2002.
  1. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    Ok so I am trying to pull the rear yoke of my t-case (np203 w/part time) and I put this giant freakin wrench on the nut, give it a clean yank and I hear a pop. The marks I made on the case and yokes are misaligned now and there seems to be a fair amount of play in it about a 1/4 inch either way.
    1. What the hell happened?
    2. Is there a trick to pulling that yoke?
    HELP!!
    Jeff
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I don't know what you did to it, but I usually use a big pipe wrench to hold the yoke. Put a long cheater pipe on the handle of the pipe wrench, and let it rest on the ground.
  3. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    ok so I am gonna try an impact wrench in the morning (had to borrow it from a buddy along with a compressor). I tried to hold the yoke in place with a chunk of wood and only managed to start lifting the t-case! Someone has to have a trick up their sleeve...
    Jeff
  4. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I did what Blazer1970 did and it worked for me
